17 years agoPCI Express Dev. Board (Stratix II GX) with Core problems
Hi there! I am having big trouble getting a design to run that contains a PCI Express Compiler Variation only. PCIE Parameters are: - Native Endpoint - 1.1 - x8 - Avalon-ST Interfa...
16 years agoHi,
I have exactly the same problem. If I load the design after BIOS and OS startup, I just do a pci bus rescan ( easy under linux ) and it's working fine. BUT, If I reboot the pc with my design loaded into devboard, the bios hangs forever, and nothings happens. I don't understand why. The Altera reference designs work fine, but not mine. What could be a reason for that ? Did you find the solution ? Regards, Arnaud
