15 years agoPC <-> S530Dev. Bd. Reg R/W interface?
Hi - so I just got my first Altera Development kit (S-IV GX S530). My "hello world" project starts with a tiny user-designed design (i.e. RTL code) that I download to the board that consists of so...
15 years ago --- Quote Start --- Can higher level applications (like LabView) talk to the Altera application on the host? --- Quote End --- Not without a little extra work. There are effectively two separate methods to create JTAG interfaces; low-level access via the Virtual JTAG IP core, and access via SOPC Builder components such as the JTAG to Avalon-MM master bridge. Both of these IP components come with a corresponding set of Tcl procedures. The Tcl procedures access the JTAG interface via DLLs with unpublished APIs. There are posts explaining how to use some of these directly, but I have not tried this. I've used both the Virtual JTAG and Avalon-MM IP cores. I'd recommend playing with the Avalon-MM IP first. Using Qsys or SOPC Builder, create a system with a JTAG to Avalon-MM master, a RAM block, and a GPIO block, and use SystemConsole Tcl commands to access this system. I recall a fairly decent webinar on the topic ... perhaps it was one of these http://www.altera.com/support/examples/on-chip-debugging/on-chip-debugging.html Have a look at that stuff, and if it becomes too confusing, I'll create a design and some scripts for you to play with. Back, to your original question; Labview cannot talk to any of these IP cores directly, since the access is via a console in an Altera application. However, you can write a Tcl server, start that using the appropriate quartus command-line tool and then use sockets from Labview. Not ideal, but not too ugly either. Cheers, Dave
