15 years agoPartial Reconfiguration in DE2
Greetings! I posted a while back about a digital image processing platform that demonstrates a jpeg compression algorithm to process the image. The JPEG encoding is an option that a user can ap...
15 years agoHi Mark,
To make things clearer, the "scan chain" you mentioned in your earlier posts refers to the JTAG chain, while the one I was referring to (dubbed "soft" Partial Reconfiguration Block - designed yourself) does not refer to the JTAG chain. This of course, has to be a separate interface from the JTAG interface, and you can use any standard interfaces like RS232, USB, etc. or even use your own non-standard interface with your own header. Hope this explanation is clear for you. Regards, Daniel
