CJohn56
7 years agoOpenCL 19.3 SD Card image for Intel Arria 10 Development Kit
Hi, I am having problems with creating my own SD Card image for the Intel Arria 10 Development Kit. I have tried the GSRD 19.1, but I cannot get the OpenCL Driver working. I have also tried genera...
MEIYAN_L_Intel
6 years agoHi,
According to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_soc_eds.pdf stated: "The handoff settings are output from the Intel Quartus Prime Standard Edition compilation and are located in the / hps_isw_handoff/ directory (where is the HPS component name in Platform Designer (Standard)). You must update the hardware handoff files and regenerate the BSP each time a hardware change impacts the HPS, such as after pin multiplexing or pin assignment changes."
The handoff folder should be there when you compile the qsys which contains the HPS component, I would like to know whether the .qsys file have HPS component?
