Gouri
2 years agoOn chip flash memory not updating avmm_data_readvalid signal in Read operation
https://www.intel.com/content/dam/altera-www/global/en_US/uploads/7/73/MAX10_On-Chip_Flash_IP_Read_Operation_Example.pdf With respect above document of read write operation in On chip flash UFM IP...
ShengN_altera
2 years agoHi Gouri Adsure,
Do you have any further update on where is the respective entity module eLADEP_NVM?
Sheng
Gouri
2 years agoHello
Code - eLADEP_NVM is just a IP instantiated just given the different name for IP instant as per project
Other things are same as per ufm_write_test_project.par
Still We stuck at read operation of UFM IP as avmm_data_addr is not incrementing
Please check the code
Below is screen shot for your reference
Thank You
Gouri Adsure
