Gouri
2 years agoOn chip flash memory not updating avmm_data_readvalid signal in Read operation
https://www.intel.com/content/dam/altera-www/global/en_US/uploads/7/73/MAX10_On-Chip_Flash_IP_Read_Operation_Example.pdf With respect above document of read write operation in On chip flash UFM IP...
ShengN_altera
2 years agoHi Gouri Adsure,
No. I tested on the original design. May I know where you get the code from? Do you mean replace the original design flash ip with the code above mentioned?
And then for component eLADEP_NVM, where is the respective entity module?
Sheng
