Noise on DE2 Board (audio issue)
Hi, from some time i have big problem with noise, I have altera de2 board (NOT 70), I clock XCK clock using 18432000 Khz clock from PLL (actualy 18421053). Everything is good, but i've got noise on about 6 bits, i feed signal from board to AMP and noise is amplificated which is bad for me :) ... Anyway, i looked at ADCDAT compared to ADCLRCK pin on logic analyser and osciloscope, noise is on ADCDAT line.I connected audio in to LEDs for positive part of signal and 5 and half of leds is blinking always. Even when i short circuit both channels of MIC or line in to ground. I thought that it is becouse of 10khz difference betwen proper XCK and these which i feed to it. But it can't be changed, oh and i got information in warnings about :
altpll:altpll_component|pll" output port clk feeds output pin "AUD_XCK" via
non-dedicated routing -- jitter performance depends on switching rate of other design elements.
Use PLL dedicated clock outputs to ensure jitter performance
But i don't have any idea how to connect these clocks via proper way... Maybe it is the couse of noise ? My I2C is configured that way : when inLeft => daneDoWyslania <= X"3400" & "000" & volIn;
when inRight => daneDoWyslania <= X"3402" & "000" & volIn;
when outLeft => daneDoWyslania <= X"3404" & "0" & volOut;
when outRight => daneDoWyslania <= X"3404" & "0" & volOut;
when analog => daneDoWyslania <= X"340815";
when digital => daneDoWyslania <= X"340A06";
when power => daneDoWyslania <= X"340C00";
when format => daneDoWyslania <= X"340E01";
when sampling => daneDoWyslania <= X"341002";
when on => daneDoWyslania <= X"341201"; --EDIT I attach screen of logic analyser , upper signal is ADCLRCK, 1 is left chan, 0 is right chan, 48Khz sampling, lower is ADCDAT line .... http://dark.art.pl/~kvasir/noise.jpg --EDIT2 Aha .... Strange behaviour ... When i stuck my board(plexiglass cover) with finger led's are blinking and from AMP i hear this stucking ... Board works like MICrophone, even when nothing is connected to input of codec ... is it normal ? For me very strange ... Any help is appreciated, thank you and i'm waiting for replies...1 Reply
Anybody ? Help ?
