ginger919's avatar
ginger919
3 years ago
NoC Initiator Bandwidth
I was using the Power Thermal Calculator (PTC) to check NoC power and I entered the required read and write bandwidth for an initiator as 22.4GBps and 22.4GBps. It threw out an error saying the bandwidth (read+write) utilization percentage should not exceed 100%. It was 200% in this case.
Isn't the read bandwidth = 256 bits x 700 MHz = 22.4GBps?
Isn't the write bandwidth = 256 bits x 700MHz = 22.4GBps?
Is the NoC initiator - switch connection a half duplex connection?
Why is total NoC initiator bandwidth (read+write) 22.4GBps?
1 Reply
