17 years agonis2 dev kit sdram verify failed
I am using Nios2 dev kit(cyclone2), and quatus8.1,
could rebuild sopc and compile example nios2 standard project successfully. but encountered the following problem when run sample application ---------------------------------- Downloading 02100020 ( 0%) Downloading 04000000 ( 0%) Downloading 04010000 (65%) Downloaded 98KB in 1.7s (57.6KB/s) Verifying 02100020 ( 0%) Verifying 04000000 ( 0%) Verify failed between address 0x4000000 and 0x400FFFF Leaving target processor paused ------------------------------------ I've found there is some post about verifi failed problem, but that seems because of customized H/W, I just used altera dev kit and sample project. so is it physical H/W problem? Could someone help me ? Thanks!1 Reply
I have the same problem, so does anyone know that?
