NIOSV Processor boot from QSPI Flash on MAX 10 Dev Kit
- 3 years ago
I have checked the Generic Serial Flash Interface Intel® FPGA IP User Guide.
The supported flash devices for configuration memory are, EPCQ, EPCQ-A, EPCQ-L, and
Micron* MT25Q (256Mb to 2Gb) devices. Unfortunately N25Q512A83 is not supported for booting NIOSV with MAX10 device.
Hope this clear your doubts.
Thank you.
Kelly
Unfortunately, the Flash Controller core does not support booting NIOS V from QSPI flash and here are the information for your reference: https://www.intel.com/content/www/us/en/docs/programmable/683130/23-1/fpga-serial-flash-controller-core.html
Thank you.
Kelly
I exactly got it that using serial flash controller IP, NIOSV would not boot. But what about Generic Serial Flash Interface IP ?
Below link refers to the NIOSV Booting Methods in which we can boot from QSPI Flash using Generic Serial Flash Interface IP:
The reference in the above link is for A10 SoC Development Kit. But I want to boot the NIOSV for MAX10 Dev Kit. As MAX10 Dev Kit have only internal configuration, I am downloading the (Hardware Image).sof/.pof in the FPGA. And I have generated another .pof file that consists my software image(.hex) which I am downloading in the QSPI Flash. I am facing no issues till this point. But after, my NIOSV is not getting booted from QSPI Flash.
So my question is does Generic Serial Flash Interface Intel FPGA IP supports QSPI Flash : N25Q512A83GSF40F to boot NIOSV specifically for MAX10 Dev Kit ?
Your response will be appreciated.
Himanshu
