NIOSV Processor boot from QSPI Flash on MAX 10 Dev Kit
- 3 years ago
I have checked the Generic Serial Flash Interface Intel® FPGA IP User Guide.
The supported flash devices for configuration memory are, EPCQ, EPCQ-A, EPCQ-L, and
Micron* MT25Q (256Mb to 2Gb) devices. Unfortunately N25Q512A83 is not supported for booting NIOSV with MAX10 device.
Hope this clear your doubts.
Thank you.
Kelly
Hi Himanshu,
It should be able to work as long as you add it in as a new configuration device and this is the list of supported flash types: https://www.intel.com/content/www/us/en/docs/programmable/683130/23-1/configuration-device-types-43525.html
Thank you.
Kelly
- himanshuvaria3 years ago
The list supported flash types is for Generic Quad SPI Controller IP, but I am using Generic Serial Flash Controller IP. Does is make any difference.
Also please refer the below image from Generic Quad SPI Controller IP
It tells that if we use Generic Quad SPI Controller IP, then NIOSV will not boot. So does it apply for Generic Serial Flash Controller IP too ?
Please share your response.
Himanshu
