14 years agoniosii ethernet std design 3c25 neek critical warnings
Hi, When I build the NIOS2 Ethernet Standard Design for the 3C25 Neek I see some critical warnings (see below), and I was curious if there are any patches available for this issue, or perhaps t...
14 years agoStill stuck attempting to resolve this error (which prevents timing from being made).
Critical Warning: Synopsys Design Constraints File file not found: 'sdram_phy_ddr_timing.sdc'. A Synopsys Design Constraints File is required by the TimeQuest Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design. I am using the ethernet standard design unmodified. The file in question does exist under a different name - eth_std_main_system_sdram_phy_ddr_timing.sdc. When I search the entire design I find only this in a hif file. This file _does_ exist so I don't know how to proceed. lib_eth_std_main_system eth_std_main_system|synthesis|submodules|eth_std_main_system_sdram_phy_ddr_timing.sdc lib_eth_std_main_system
