15 years agoNiosII 10.1 Eclipse(Problem) - have you programmed the filling system into flash?
Good evening of Members
I want test the de2-115 of example (DE2_115_WEB_SERVER_RGMII_ENET0) but , when I Ram_as , niosII 10.1 appear the message of error ---------------------------------------------------------------- Fetching file: /mnt/rozipfs/index.html. Can't open the 404 File Not Found error page. Have you programmed the filing system into flash? [http_handle_receive] Error preparing response ---------------------------------------------------------------- so I reference "http://alteraforum.org/forum/showthread.php?p=115825" and I try for renew (New→NiosII Application and BSP from Template) Select after of Project and Templates choose Web Server(RGMII) Then I open Nios 10.1 Command Shell and I enter the code: ---------------------------------------------------------------- cd d:/demo/DE2_115_Web_Server/DE2_115_WEB_SERVER_RGMII_ENET0 mkdir flash bin2flash --location=0x100000 --input=/software/web_server_test/system/ro_zipfs.zip --output=ro.flashfs_cfi_flash1.flash nios2-flash-programmer.exe ro.flashfs_cfi_flash1.flash --base=0x0a800000 --sidp=0x9000140 --id=0x0 --device=1 --instance=0 --program --verbose --erase-all ---------------------------------------------------------------- but , In the start enter "nios2-flash..." It tell me , There are two or more JTAG cables available but you have not chosen which one to use. please use the configuration dialog to pick one, or specify a value for the --cable parameter on the command line. I try very long time...but I can't solve the question...I don't know how do... p.s sorry my English is very poor.No RepliesBe the first to reply
