17 years agoNios II Flash Programmer problem in my DE1 Board
Hi,i use Nios II Flash Programmer to test Flash programmer on my DE1 Board,but it say NO CFI TABLE FOUND ON oxo. I set the flash address 0x0 in the sopc builder,and maybe i find the problem,the probl...
17 years agomaybe u should describe your question more clearly!Generally speaking,u should burn the SOF file into FPGA first after building it,then use nios2-flash-programmer to check whether the hardware conncetion is right?If there is no problem,u can burn the nios2 file into flash successfully!
Hopefully this makes sense! Handsome
