16 years agoNios II Embedded Evaluation Kit vga output problem
Hey I am using Nios II Evaluation Kit Cyclone III Edition. Quartus7.2 i download the "neek_application_selector_vga_mirror_design_example" form Nios Wiki. i display Nios II designs on a Mo...
16 years agoGood morning!
The NEEK has got the Terasic Multimedia Touch Panel Daughter Board (MTDB). I have posted the links to the Terasic resources several times here in the forum. You can find the specifications for VGA in the Manual, P.27 Table 4.4. I read from the table, that you can get 1280x1024 max, but it could be that the table is just not complete. Perhaps you give it a try and read that passage, perhaps it gives you some clues. Good luck!
