15 years agoNIOS II Embedded Elav Kit - Hello_World_0 will not run
I'm totaly new so please help tell me what I'm missing.. Have followed example of My First Software Example here (http://www.alterawiki.com/uploads/b/b2/my_first_nios2_software_tutorial_v72.pdf) but on page 1-12 I'm told to right click project and select RUN AS > NIOS II HARDWARE, however only option I have is LOCAL C/C++ APPLICATION (which tells it will not run). Why don't I have NIOS II HARDWARE. As all steps before this have worked ok - as far as I can see. Thanks Paul:confused:2 Replies
If you are running Windows XP, then remove completely Nios II EDS, install again.
If you are running Windows 7 32 or 64, please run Nios II EDS in Windows XP compatible mode. - Altera_Forum
Many thanks, am running Win7.
All working now Thank you. Paul :)
