16 years agonewbie help with WM8731 codec
Hi, I just got a cyclone ii dev kit and I'm having some problem with the audio codec on it. I'm trying to make a dsp module which gets input from the line in, so I set up the codec for appropriate...
16 years agoYou can use a scope or Signaltap probes to check the signals. It could be something as simple as a sign problem or a bit shift due to synchronization problems.
