17 years agoNew to Altera. Error on Downloading bitstream
Hi All, I'm a new to Altera and I have a Cyclone II EP2C35 devkit. I wrote a small VHDL file which waits for one of the SW buttons and toggle a led. I made the pin assignements, synthesis, .......
17 years ago --- Quote Start --- Could you explain this setting ? --- Quote End --- By default any pins you do not assign are set to outputs. One of those unassigned pins triggers the power up configuration of the FPGA from the FLASH memory - the power up condition. Setting all unused pins to inputs prevents this.
