17 years agoNew to Altera. Error on Downloading bitstream
Hi All, I'm a new to Altera and I have a Cyclone II EP2C35 devkit. I wrote a small VHDL file which waits for one of the SW buttons and toggle a led. I made the pin assignements, synthesis, .......
17 years ago --- Quote Start --- Would you please tell me how to do that ? --- Quote End --- Go to 'Assignments', 'Device' and click the bar 'Device and pin options'. Go to 'Unused Pins' and under 'Reserve all unused pins' select 'As input tri-stated' or 'as input with weak pull-up'. Then press 'OK' and 'OK' again and recompile. I use this board and that resetting problem is nearly always caused by this issue.
