15 years agoNEEK. Error Loading Application
Hi everyone. I'm just starting to work with Nios II Embedded Evaluation Kit. When I wanted to watch demos from SD card, it gave me an error: error loading application <name>. And the loading ba...
15 years agoYou are absolutly right.
I used to work with examples from AlteraWiki and somehow damaged flash content of application selector (one of possible reasons, because after restoring it works fine and application selector too). Fail of restoring original flash is only my fault (I used wrong command). So if you follow intstructions from user guide, it will fine. But in addition to address you have include your cable: --cable=USB-Blaster Best wishes, Yaroslav
