16 years agoNEEK Cyc.III - TPG to Touch LCD flackert - bitte um Hilfe
Hallo zusammen, ich arbeite mit dem Nios II Embedded Evaluation Kit in der CycloneIII Edition mit terasiC Erweiterungsboard. Als Arbeitsprojekt habe ich aus dem NIOS_Evaluation_Kit_v8.0 das Exa...
16 years ago --- Quote Start --- So if I get this right, I can use the SGDMA-scatter module (like used in the picture viewer example) in combination with the video sync generator. But if I want to use the alpha blender, test pattern generator,... (VIP elements) I need to use the video clocked output and perhaps the frame reader instead of the SGDMA-scatterer? --- Quote End --- That´s how I think it is. The cores from the VIP Suite use the "Avalon-ST Video protocol", therefore streams following other protocols have to be properly converted, e.g. by the use of the Frame Reader instead of the SGDMA.
