RVadl2
5 years agoNeed the test code for I2C_RSU
Hi @Ana_R_Intel1 ,
I am trying out the I2C_RSU project in the below link using a Max 10 Development board. I understand this slave code will help in loading the 10M50 FPGA with a new image through ...
JohnT_Altera
5 years agoHi,
There is no setting for this as the FPGA should be able to handle the clk speed. If you are not confident then I would recommend you to implement the timing constraint to make sure it is meeting the highest frequency you are planning to used.
RVadl2
5 years agoHi,
I was able to perform RSU with I2C_RSU example through i2c interface of Arduino.
Thanks for the support. Now, I am trying to replace the I2C interface with SPI.
Can you let me know the SPI Avalon 32 bit write and read format, as you mentioned with I2C earlier.
Ravi Kanth V
