RVadl2
5 years agoNeed the test code for I2C_RSU
Hi @Ana_R_Intel1 ,
I am trying out the I2C_RSU project in the below link using a Max 10 Development board. I understand this slave code will help in loading the 10M50 FPGA with a new image through ...
JohnT_Altera
5 years agoHi,
There is no setting for this as the FPGA should be able to handle the clk speed. If you are not confident then I would recommend you to implement the timing constraint to make sure it is meeting the highest frequency you are planning to used.
RVadl2
5 years agoHi,
Can you also let me know, which are the correct addresses for control register and status register for on-chip flash?
Ravi
