17 years agoNEED HELP in audio signal processing
i am using DE1 Board equipped with Cyclone II, im juz a newbie in FPGA, pls help me in this project.. i wound like to know how to perform the fast furior transform
17 years agoYou should solve it in the following order.
1. Be familiar with your board and audio CODEC. 2. Write or get a module to drive the audio CODEC. Use it and understand it. 2. Choose between a pure hardware solution or a Nios II based solution. 3. If you have choosen a pure hardware solution there is a lot of stuff to study about fft implementation: Altera core, own core, open core. 4. If you have choosen a Nios II based solution you must connect your audio CODEC module as an slave peripheral. Internet is full of C language based FFT implementations.
