16 years agoNeed help creating a simple 32bit counter
I'm trying to learn VHDL so I thought I'd try converting the "my_first_fpga" example from verilog to VHDL (how complicated can adding one to a number be?), three hours later, lots of googling and sea...
16 years agoI found the "Start Compilation and Simulation" option in Quartus which saves a few steps, however I thought I'd try setting up a test bench. I installed ModelSim, when I run the simulation and look in wave I can see the clock but counter_out has no value. Did I set this up correctly?
-- import std_logic from the IEEE library
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
-- this is the entity
entity counter_example is
port (
counter_out : buffer unsigned(31 downto 0));
end counter_example;
architecture counter_code of counter_example is
signal clock : std_logic := '0';
begin
process (clock)
begin
clock <= not clock after 10 ns; --will give 50MHz clock
if rising_edge(clock) then
counter_out <= counter_out + 1;
end if;
end process;
end counter_code; Thanks
