maxdd's avatar
maxdd
5 years ago
N3000 Sample Test: Native Loopback fail
I try to run Sample Test: Native Loopback by using 'sudo ./hello_fpga', but it gives error
Using OPAE C library version '1.3.7' build '81afe79'
Error no matching accelerator: not found
'lspci | grep acc' gives
08:00.0 Processing accelerators: Intel Corporation Device 0b30
I also try to use 'sudo ./hello_fpga -B 0x08' but it gives the same error.
Any idea on how to solve this? Thanks!
  • Wincent_Altera's avatar
    Wincent_Altera
    I might need the below info (PrintScreen will help)
    • rpm -qa | grep opae
      check the OPAE version, also to confirm the step is correct.
    The hello_fpga sample host application uses the OPAE library to test the hardware in native loopback mode (NLB).
    I would suggest referring back to session 7.2.1 at link below (for detailed setup)
    What you have to do is the following
    1. cd sw_sample
    2. gcc -o hello_fpga -std=gnu99 -rdynamic -ljson-c -luuid -lpthread -lopae-c -lm -Wl,-rpath -lopae-c hello_fpga.c
    3. sudo sh -c "echo 20 > /sys/kernel/mm/hugepages/hugepages-2048kB/nr_hugepages"
    4. sudo ./hello_fpga
    [guest@hw-rae-a3-l sw_sample]$ sudo ./hello_fpga
    Using OPAE C library version '1.3.3' build 'c6c0d9f'
    Running Test
    Running on bus 0x07.
    dfh = 100000008000001f
    id[0] = c000c9660d824272
    id[1] = 9aeffe5f84570612
    dfh = 2000000080000000
    id[0] = a9149a35bace01ea
    id[1] = ef82def7f6ec40fc
    dfh = 1000010080001070
    id[0] = f89e433683f9040b
    id[1] = d8424dc4a4a3c413
    Found NLB0 at offset 0x28000
    Done Running Test
    Let me know if this helps.
    WeiChuan_C_Intel
    • maxdd's avatar
      maxdd
      Thanks for the reply.
      When following the tutorial, I don't know what is this variable '$OPAE_PLATFORM_ROOT'. After installation, I only have two folders. Here is the folder structures. (I only show 2 levels)
      intelrtestack
      ├── bin
      │   ├── init_env.sh
      │   ├── sr_vista_rot_2x2x25-v1.3.16.bin
      │   └── sr_vista_rot_4x25G-v1.3.16.bin
      ├── src
      │   ├── opae-1.3.7-5
      │   ├── opae.admin-1.0.3
      │   ├── opae-intel-fpga-driver-2.0.1-10.src.rpm
      │   └── opae.pac_sign-1.0.4
      └── sw_sample
          └── hello_fpga.c
      inteldevstack
      ├── bin
      ├── intelFPGA_pro
      │   ├── devdata
      │   ├── ip
      │   ├── licenses
      │   ├── logs
      │   ├── nios2eds
      │   ├── qsys
      │   ├── quartus
      │   └── syscon
      ├── rtl
      │   └── n3000_1_3_v1.5.7
      └── src
          ├── opae-1.3.7-5
      I am using 'N3000-2', the link you send me is for 'Intel Arria 10 GX FPGA', not for 'N3000-2', is that correct?
      Here is the output
      rpm -qa | grep opae
      opae-intel-fpga-driver-2.0.1-10.x86_64
      opae-libs-1.3.7-5.el7.x86_64
      opae-devel-1.3.7-5.el7.x86_64
      opae-tools-1.3.7-5.el7.x86_64
      opae-tools-extra-1.3.7-5.el7.x86_64
      opae.admin-1.0.3-2.el7.noarch
      opae.pac_sign-1.0.4-3.el7.x86_64
        Wincent_Altera
        Hi Max,
        How about the test result of "fpgainfo fme" and "fpgabist" ?
        Apologize for wrong doc, can you please try out doc below
        Just want to ensure that the step is correct, please let me know if you are still unable to get it.
        WeiChuan_C_Intel
