N3000 Sample Test: Native Loopback fail
I might need the below info (PrintScreen will help)
- rpm -qa | grep opae
check the OPAE version, also to confirm the step is correct.
The hello_fpga sample host application uses the OPAE library to test the hardware in native loopback mode (NLB).
I would suggest referring back to session 7.2.1 at link below (for detailed setup)
- https://www.intel.com/content/www/us/en/programmable/documentation/iyu1522005567196.html
- Follow the provided step, please let me know if you facing any problem.
What you have to do is the following
- cd sw_sample
- gcc -o hello_fpga -std=gnu99 -rdynamic -ljson-c -luuid -lpthread -lopae-c -lm -Wl,-rpath -lopae-c hello_fpga.c
- sudo sh -c "echo 20 > /sys/kernel/mm/hugepages/hugepages-2048kB/nr_hugepages"
- sudo ./hello_fpga
[guest@hw-rae-a3-l sw_sample]$ sudo ./hello_fpga
Using OPAE C library version '1.3.3' build 'c6c0d9f'
Running Test
Running on bus 0x07.
dfh = 100000008000001f
id[0] = c000c9660d824272
id[1] = 9aeffe5f84570612
dfh = 2000000080000000
id[0] = a9149a35bace01ea
id[1] = ef82def7f6ec40fc
dfh = 1000010080001070
id[0] = f89e433683f9040b
id[1] = d8424dc4a4a3c413
Found NLB0 at offset 0x28000
Done Running Test
Let me know if this helps.
WeiChuan_C_Intel
- maxdd5 years ago
Thanks for the reply.
When following the tutorial, I don't know what is this variable '$OPAE_PLATFORM_ROOT'. After installation, I only have two folders. Here is the folder structures. (I only show 2 levels)
intelrtestack ├── bin │ ├── init_env.sh │ ├── sr_vista_rot_2x2x25-v1.3.16.bin │ └── sr_vista_rot_4x25G-v1.3.16.bin ├── src │ ├── opae-1.3.7-5 │ ├── opae.admin-1.0.3 │ ├── opae-intel-fpga-driver-2.0.1-10.src.rpm │ └── opae.pac_sign-1.0.4 └── sw_sample └── hello_fpga.c inteldevstack ├── bin │ ├── sr_vista_rot_2x2x25-v1.3.16.bin │ └── sr_vista_rot_4x25G-v1.3.16.bin ├── intelFPGA_pro │ ├── devdata │ ├── ip │ ├── licenses │ ├── logs │ ├── nios2eds │ ├── qsys │ ├── quartus │ └── syscon ├── rtl │ └── n3000_1_3_v1.5.7 └── src ├── opae-1.3.7-5 ├── opae.admin-1.0.3 ├── opae-intel-fpga-driver-2.0.1-10.src.rpm └── opae.pac_sign-1.0.4I am using 'N3000-2', the link you send me is for 'Intel Arria 10 GX FPGA', not for 'N3000-2', is that correct?
Here is the output
rpm -qa | grep opae opae-intel-fpga-driver-2.0.1-10.x86_64 opae-libs-1.3.7-5.el7.x86_64 opae-devel-1.3.7-5.el7.x86_64 opae-tools-1.3.7-5.el7.x86_64 opae-tools-extra-1.3.7-5.el7.x86_64 opae.admin-1.0.3-2.el7.noarch opae.pac_sign-1.0.4-3.el7.x86_64- Wincent_Altera5 years ago
Hi Max,
How about the test result of "fpgainfo fme" and "fpgabist" ?
Apologize for wrong doc, can you please try out doc below
- Intel® Acceleration Stack User Guide, Intel FPGA Programmable Acceleration Card N3000
- Page 32/92, Session 6 Native : Loopback
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-ias-n3000.pdf
- Please follow the step from extract the package to sudo ./hello_fpga
Just want to ensure that the step is correct, please let me know if you are still unable to get it.
WeiChuan_C_Intel
- maxdd5 years ago
I think there is the correct doc for N3000-2?
https://www.intel.com/content/www/us/en/programmable/documentation/zsf1588015530773.html
I follow the instruction on this doc and I also follow the instructions on the doc you suggest, but none of them work.
Here is the error and the output for "fpgainfo fme" and "fpgabist".
sudo ./hello_fpga -B 0x08 Using OPAE C library version '1.3.7' build '81afe79' Error no matching accelerator: not found fpgainfo fme Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** FME ******// Object Id : 0xF100000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 Boot Page : user fpgabist -i 0x0b30 ========================================================== Beginning FPGA Built-In Self-Test ========================================================== Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** FME ******// Object Id : 0xF100000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 Boot Page : user Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** PORT ******// Object Id : 0xF000000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 Accelerator Id : 850adcc2-6ceb-4b22-9722-d43375b61c66 Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** TEMP ******// Object Id : 0xF100000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 (12) FPGA Core Temperature : 44.00 Celsius (13) Board Temperature : 30.00 Celsius (15) QSFP A Temperature : N/A (38) QSFP B Temperature : N/A (44) Retimer A Core Temperature : 49.00 Celsius (45) Retimer A Serdes Temperature : 49.50 Celsius (46) Retimer B Core Temperature : 50.00 Celsius (47) Retimer B Serdes Temperature : 51.00 Celsius Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** POWER ******// Object Id : 0xF100000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 ( 1) Board Power : 46.28 Watts ( 2) 12V Backplane Current : 2.13 Amps ( 3) 12V Backplane Voltage : 11.95 Volts ( 4) 1.2V Voltage : 1.20 Volts ( 6) 1.8V Voltage : 1.82 Volts (3.3V Voltage : 3.29 Volts (10) FPGA Core Voltage : 0.90 Volts (11) FPGA Core Current : 5.84 Amps (14) QSFP A Voltage : N/A (24) 12V AUX Current : 1.74 Amps (25) 12V AUX Voltage : 11.96 Volts (37) QSFP B Voltage : N/A Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** FME ERRORS ******// Object Id : 0xF100000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 PCIe0 Errors : 0x0 PCIe1 Errors : 0x0 Catfatal Errors : 0x0 Seu Emr : 0x0 Inject Error : 0x0 Nonfatal Errors : 0x0 Next Error : 0x0 First Error : 0x0 Errors : 0x0 Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** PORT ERRORS ******// Object Id : 0xF000000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 Accelerator Id : 850adcc2-6ceb-4b22-9722-d43375b61c66 First Malformed Req : 0x0 First Error : 0x0 Errors : 0x0 Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** PHY ******// Object Id : 0xF100000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 //****** PHY GROUP 0 ******// Open /dev/char/10:56 failed //****** PHY GROUP 1 ******// Open /dev/char/10:55 failed //****** Intel C827 Retimer ******// Port0 10G : Down Port1 10G : Down Port2 10G : Down Port3 10G : Down Port4 10G : Down Port5 10G : Down Port6 10G : Down Port7 10G : Down Retimer A Version : 101c.1064 Retimer B Version : 101c.1064 Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** MAC ******// Object Id : 0xF100000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 Number of MACs : 8 MAC address 0 : 64:4C:36:12:E8:C8 MAC address 1 : 64:4C:36:12:E8:C9 MAC address 2 : 64:4C:36:12:E8:CA MAC address 3 : 64:4C:36:12:E8:CB MAC address 4 : 64:4C:36:12:E8:CC MAC address 5 : 64:4C:36:12:E8:CD MAC address 6 : 64:4C:36:12:E8:CE MAC address 7 : 64:4C:36:12:E8:CF Running mode: nlb Running fpgadiag lpbk1 vh0-vh0 test... AFU NLB not found Error: configuration failed. Failed Test: vh0-vh0 Command 'fpgadiag -B 0x8 --mode=lpbk1 --read-vc=vh0 --write-vc=vh0 --multi-cl=4 --begin=1024 --end=1024 --timeout-sec=1 --cont -G 850adcc2-6ceb-4b22-9722-d43375b61c66 -T 200000000' returned non-zero exit status 102. Running fpgadiag lpbk1 vh0-vh1 test... AFU NLB not found Error: configuration failed. Failed Test: vh0-vh1 Command 'fpgadiag -B 0x8 --mode=lpbk1 --read-vc=vh0 --write-vc=vh1 --multi-cl=4 --begin=1024 --end=1024 --timeout-sec=1 --cont -G 850adcc2-6ceb-4b22-9722-d43375b61c66 -T 200000000' returned non-zero exit status 102. Running fpgadiag lpbk1 vh1-vh0 test... AFU NLB not found Error: configuration failed. Failed Test: vh1-vh0 Command 'fpgadiag -B 0x8 --mode=lpbk1 --read-vc=vh1 --write-vc=vh0 --multi-cl=4 --begin=1024 --end=1024 --timeout-sec=1 --cont -G 850adcc2-6ceb-4b22-9722-d43375b61c66 -T 200000000' returned non-zero exit status 102. Running fpgadiag lpbk1 vh1-vh1 test... AFU NLB not found Error: configuration failed. Failed Test: vh1-vh1 Command 'fpgadiag -B 0x8 --mode=lpbk1 --read-vc=vh1 --write-vc=vh1 --multi-cl=4 --begin=1024 --end=1024 --timeout-sec=1 --cont -G 850adcc2-6ceb-4b22-9722-d43375b61c66 -T 200000000' returned non-zero exit status 102. Finished Executing NLB (FPGA DIAG) Tests Running mode: dma_afu Running fpga_dma_test test on DDR4_A... Running test in HW mode AFU DMA not found Error fpgaDmaOpen: not found Failed Test: fpga_dma_test 0 -B 0x8 -D 0 -S 4294967296 -G 850adcc2-6ceb-4b22-9722-d43375b61c66 Command 'fpga_dma_test 0 -B 0x8 -D 0 -S 4294967296 -G 850adcc2-6ceb-4b22-9722-d43375b61c66' returned non-zero exit status 1. Running fpga_dma_test test on DDR4_B... Running test in HW mode AFU DMA not found Error fpgaDmaOpen: not found Failed Test: fpga_dma_test 0 -B 0x8 -D 1 -S 4294967296 -G 850adcc2-6ceb-4b22-9722-d43375b61c66 Command 'fpga_dma_test 0 -B 0x8 -D 1 -S 4294967296 -G 850adcc2-6ceb-4b22-9722-d43375b61c66' returned non-zero exit status 1. Running fpga_dma_test test on DDR4_C... Running test in HW mode AFU DMA not found Error fpgaDmaOpen: not found Failed Test: fpga_dma_test 0 -B 0x8 -D 2 -S 1073741824 -G 850adcc2-6ceb-4b22-9722-d43375b61c66 Command 'fpga_dma_test 0 -B 0x8 -D 2 -S 1073741824 -G 850adcc2-6ceb-4b22-9722-d43375b61c66' returned non-zero exit status 1. Running fpga_dma_test test on QDR... Running test in HW mode AFU DMA not found Error fpgaDmaOpen: not found Failed Test: fpga_dma_test 0 -B 0x8 -D 3 -S 16777216 -G 850adcc2-6ceb-4b22-9722-d43375b61c66 Command 'fpga_dma_test 0 -B 0x8 -D 3 -S 16777216 -G 850adcc2-6ceb-4b22-9722-d43375b61c66' returned non-zero exit status 1. Finished Executing DMA Tests Built-in Self-Test Completed.
