N3000 Sample Test: Native Loopback fail
I might need the below info (PrintScreen will help)
- rpm -qa | grep opae
check the OPAE version, also to confirm the step is correct.
The hello_fpga sample host application uses the OPAE library to test the hardware in native loopback mode (NLB).
I would suggest referring back to session 7.2.1 at link below (for detailed setup)
- https://www.intel.com/content/www/us/en/programmable/documentation/iyu1522005567196.html
- Follow the provided step, please let me know if you facing any problem.
What you have to do is the following
- cd sw_sample
- gcc -o hello_fpga -std=gnu99 -rdynamic -ljson-c -luuid -lpthread -lopae-c -lm -Wl,-rpath -lopae-c hello_fpga.c
- sudo sh -c "echo 20 > /sys/kernel/mm/hugepages/hugepages-2048kB/nr_hugepages"
- sudo ./hello_fpga
[guest@hw-rae-a3-l sw_sample]$ sudo ./hello_fpga
Using OPAE C library version '1.3.3' build 'c6c0d9f'
Running Test
Running on bus 0x07.
dfh = 100000008000001f
id[0] = c000c9660d824272
id[1] = 9aeffe5f84570612
dfh = 2000000080000000
id[0] = a9149a35bace01ea
id[1] = ef82def7f6ec40fc
dfh = 1000010080001070
id[0] = f89e433683f9040b
id[1] = d8424dc4a4a3c413
Found NLB0 at offset 0x28000
Done Running Test
Let me know if this helps.
WeiChuan_C_Intel
Thanks for the reply.
When following the tutorial, I don't know what is this variable '$OPAE_PLATFORM_ROOT'. After installation, I only have two folders. Here is the folder structures. (I only show 2 levels)
intelrtestack ├── bin │ ├── init_env.sh │ ├── sr_vista_rot_2x2x25-v1.3.16.bin │ └── sr_vista_rot_4x25G-v1.3.16.bin ├── src │ ├── opae-1.3.7-5 │ ├── opae.admin-1.0.3 │ ├── opae-intel-fpga-driver-2.0.1-10.src.rpm │ └── opae.pac_sign-1.0.4 └── sw_sample └── hello_fpga.c inteldevstack ├── bin │ ├── sr_vista_rot_2x2x25-v1.3.16.bin │ └── sr_vista_rot_4x25G-v1.3.16.bin ├── intelFPGA_pro │ ├── devdata │ ├── ip │ ├── licenses │ ├── logs │ ├── nios2eds │ ├── qsys │ ├── quartus │ └── syscon ├── rtl │ └── n3000_1_3_v1.5.7 └── src ├── opae-1.3.7-5 ├── opae.admin-1.0.3 ├── opae-intel-fpga-driver-2.0.1-10.src.rpm └── opae.pac_sign-1.0.4
I am using 'N3000-2', the link you send me is for 'Intel Arria 10 GX FPGA', not for 'N3000-2', is that correct?
Here is the output
rpm -qa | grep opae opae-intel-fpga-driver-2.0.1-10.x86_64 opae-libs-1.3.7-5.el7.x86_64 opae-devel-1.3.7-5.el7.x86_64 opae-tools-1.3.7-5.el7.x86_64 opae-tools-extra-1.3.7-5.el7.x86_64 opae.admin-1.0.3-2.el7.noarch opae.pac_sign-1.0.4-3.el7.x86_64
- Wincent_Altera4 years ago
Hi Max,
How about the test result of "fpgainfo fme" and "fpgabist" ?
Apologize for wrong doc, can you please try out doc below
- Intel® Acceleration Stack User Guide, Intel FPGA Programmable Acceleration Card N3000
- Page 32/92, Session 6 Native : Loopback
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-ias-n3000.pdf
- Please follow the step from extract the package to sudo ./hello_fpga
Just want to ensure that the step is correct, please let me know if you are still unable to get it.
WeiChuan_C_Intel
- maxdd4 years ago
I think there is the correct doc for N3000-2?
https://www.intel.com/content/www/us/en/programmable/documentation/zsf1588015530773.html
I follow the instruction on this doc and I also follow the instructions on the doc you suggest, but none of them work.
Here is the error and the output for "fpgainfo fme" and "fpgabist".
sudo ./hello_fpga -B 0x08 Using OPAE C library version '1.3.7' build '81afe79' Error no matching accelerator: not found fpgainfo fme Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** FME ******// Object Id : 0xF100000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 Boot Page : user fpgabist -i 0x0b30 ========================================================== Beginning FPGA Built-In Self-Test ========================================================== Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** FME ******// Object Id : 0xF100000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 Boot Page : user Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** PORT ******// Object Id : 0xF000000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 Accelerator Id : 850adcc2-6ceb-4b22-9722-d43375b61c66 Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** TEMP ******// Object Id : 0xF100000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 (12) FPGA Core Temperature : 44.00 Celsius (13) Board Temperature : 30.00 Celsius (15) QSFP A Temperature : N/A (38) QSFP B Temperature : N/A (44) Retimer A Core Temperature : 49.00 Celsius (45) Retimer A Serdes Temperature : 49.50 Celsius (46) Retimer B Core Temperature : 50.00 Celsius (47) Retimer B Serdes Temperature : 51.00 Celsius Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** POWER ******// Object Id : 0xF100000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 ( 1) Board Power : 46.28 Watts ( 2) 12V Backplane Current : 2.13 Amps ( 3) 12V Backplane Voltage : 11.95 Volts ( 4) 1.2V Voltage : 1.20 Volts ( 6) 1.8V Voltage : 1.82 Volts (3.3V Voltage : 3.29 Volts (10) FPGA Core Voltage : 0.90 Volts (11) FPGA Core Current : 5.84 Amps (14) QSFP A Voltage : N/A (24) 12V AUX Current : 1.74 Amps (25) 12V AUX Voltage : 11.96 Volts (37) QSFP B Voltage : N/A Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** FME ERRORS ******// Object Id : 0xF100000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 PCIe0 Errors : 0x0 PCIe1 Errors : 0x0 Catfatal Errors : 0x0 Seu Emr : 0x0 Inject Error : 0x0 Nonfatal Errors : 0x0 Next Error : 0x0 First Error : 0x0 Errors : 0x0 Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** PORT ERRORS ******// Object Id : 0xF000000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 Accelerator Id : 850adcc2-6ceb-4b22-9722-d43375b61c66 First Malformed Req : 0x0 First Error : 0x0 Errors : 0x0 Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** PHY ******// Object Id : 0xF100000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 //****** PHY GROUP 0 ******// Open /dev/char/10:56 failed //****** PHY GROUP 1 ******// Open /dev/char/10:55 failed //****** Intel C827 Retimer ******// Port0 10G : Down Port1 10G : Down Port2 10G : Down Port3 10G : Down Port4 10G : Down Port5 10G : Down Port6 10G : Down Port7 10G : Down Retimer A Version : 101c.1064 Retimer B Version : 101c.1064 Board Management Controller, MAX10 NIOS FW version D.2.1.24 Board Management Controller, MAX10 Build version D.2.0.7 //****** MAC ******// Object Id : 0xF100000 PCIe s:b:d.f : 0000:08:00.0 Device Id : 0x0b30 Numa Node : 0 Ports Num : 01 Bitstream Id : 0x23000010000000 Bitstream Version : 0.2.3 Pr Interface Id : 901dd697-ca79-4b05-b843-8138cefa2846 Number of MACs : 8 MAC address 0 : 64:4C:36:12:E8:C8 MAC address 1 : 64:4C:36:12:E8:C9 MAC address 2 : 64:4C:36:12:E8:CA MAC address 3 : 64:4C:36:12:E8:CB MAC address 4 : 64:4C:36:12:E8:CC MAC address 5 : 64:4C:36:12:E8:CD MAC address 6 : 64:4C:36:12:E8:CE MAC address 7 : 64:4C:36:12:E8:CF Running mode: nlb Running fpgadiag lpbk1 vh0-vh0 test... AFU NLB not found Error: configuration failed. Failed Test: vh0-vh0 Command 'fpgadiag -B 0x8 --mode=lpbk1 --read-vc=vh0 --write-vc=vh0 --multi-cl=4 --begin=1024 --end=1024 --timeout-sec=1 --cont -G 850adcc2-6ceb-4b22-9722-d43375b61c66 -T 200000000' returned non-zero exit status 102. Running fpgadiag lpbk1 vh0-vh1 test... AFU NLB not found Error: configuration failed. Failed Test: vh0-vh1 Command 'fpgadiag -B 0x8 --mode=lpbk1 --read-vc=vh0 --write-vc=vh1 --multi-cl=4 --begin=1024 --end=1024 --timeout-sec=1 --cont -G 850adcc2-6ceb-4b22-9722-d43375b61c66 -T 200000000' returned non-zero exit status 102. Running fpgadiag lpbk1 vh1-vh0 test... AFU NLB not found Error: configuration failed. Failed Test: vh1-vh0 Command 'fpgadiag -B 0x8 --mode=lpbk1 --read-vc=vh1 --write-vc=vh0 --multi-cl=4 --begin=1024 --end=1024 --timeout-sec=1 --cont -G 850adcc2-6ceb-4b22-9722-d43375b61c66 -T 200000000' returned non-zero exit status 102. Running fpgadiag lpbk1 vh1-vh1 test... AFU NLB not found Error: configuration failed. Failed Test: vh1-vh1 Command 'fpgadiag -B 0x8 --mode=lpbk1 --read-vc=vh1 --write-vc=vh1 --multi-cl=4 --begin=1024 --end=1024 --timeout-sec=1 --cont -G 850adcc2-6ceb-4b22-9722-d43375b61c66 -T 200000000' returned non-zero exit status 102. Finished Executing NLB (FPGA DIAG) Tests Running mode: dma_afu Running fpga_dma_test test on DDR4_A... Running test in HW mode AFU DMA not found Error fpgaDmaOpen: not found Failed Test: fpga_dma_test 0 -B 0x8 -D 0 -S 4294967296 -G 850adcc2-6ceb-4b22-9722-d43375b61c66 Command 'fpga_dma_test 0 -B 0x8 -D 0 -S 4294967296 -G 850adcc2-6ceb-4b22-9722-d43375b61c66' returned non-zero exit status 1. Running fpga_dma_test test on DDR4_B... Running test in HW mode AFU DMA not found Error fpgaDmaOpen: not found Failed Test: fpga_dma_test 0 -B 0x8 -D 1 -S 4294967296 -G 850adcc2-6ceb-4b22-9722-d43375b61c66 Command 'fpga_dma_test 0 -B 0x8 -D 1 -S 4294967296 -G 850adcc2-6ceb-4b22-9722-d43375b61c66' returned non-zero exit status 1. Running fpga_dma_test test on DDR4_C... Running test in HW mode AFU DMA not found Error fpgaDmaOpen: not found Failed Test: fpga_dma_test 0 -B 0x8 -D 2 -S 1073741824 -G 850adcc2-6ceb-4b22-9722-d43375b61c66 Command 'fpga_dma_test 0 -B 0x8 -D 2 -S 1073741824 -G 850adcc2-6ceb-4b22-9722-d43375b61c66' returned non-zero exit status 1. Running fpga_dma_test test on QDR... Running test in HW mode AFU DMA not found Error fpgaDmaOpen: not found Failed Test: fpga_dma_test 0 -B 0x8 -D 3 -S 16777216 -G 850adcc2-6ceb-4b22-9722-d43375b61c66 Command 'fpga_dma_test 0 -B 0x8 -D 3 -S 16777216 -G 850adcc2-6ceb-4b22-9722-d43375b61c66' returned non-zero exit status 1. Finished Executing DMA Tests Built-in Self-Test Completed. - Wincent_Altera4 years ago
Hi Max,
Thanks for double confirm that. We can confirm that there is no missing step/driver error.
May I know server OS and kernel version that you are using ? Currently PAC N3000 cards support:- CentOS Linux version 7.6 kernel 3.10 or kernel 4.19
- Red Hat* Enterprise Linux* (RHEL) version 7.6 kernel 3.10
- It is possible to happen if your OS is not in the suggested version or missing file (kernel headers)
Apart of that, is there any hardware you are running on ?
- IF you don’t have an FPGA platform in your system.
- It is expected for the software not to find any accelerators (well, to be fair, there aren't any ).
- If you want to run your OPAE application without hardware, you can run it against a simulation of your accelerator in the AFU Simulation Environment (ASE).
- You'll need to link your application against a different implementation of the OPAE library (libopae-c-ase instead of libopae-c) and run your accelerator RTL through a logic simulator.
- Have a look at the AFU user guide for more details on how to use ASE.
https://www.intel.com/content/www/us/en/programmable/documentation/rjg1562957780901.html - In some case, the error might also occur if the FPGA image doesn’t match the test to do, hence the software can’t connect with the AFU which has the same accelerator ID
Hope this can help you
WeiChuan_C_Intel
