16 years agoMyFirstFPGA on Stratix II PCI Express Dev Kit
Hi I am new to FPGA world and sorry if I am asking silly questions. I am trying to run MyFirstFPGA tutorial on Stratix II PCI express dev kit I followed every step specified on the tutorial ...
16 years agoI can answer one of your questions quickly. For the rest, I am not familiar with that specific board.
Each time you use differential signaling such as LVDS, you need two signals: p and n. Quatrus II will automatically generate the extra signal when you select a diff sig standard. You should always use differential signaling when you can. Make sure however that a differential clock generator is actually used to drive those pins. Look at the schematics and search for those pins and see how they are connected.
