16 years agoMy projects don't run.
Hello to everybody. I have DE1 (with EP2C20F484C7 FPGA device and EPCS4 serial configuration device). I run Quartus II v.9.1 web in a Vista computer. I have set up USB Blaster driver software in m...
16 years agoahh okay
Active Serial Programming is shortend to AS inside Altera documentation. As you use Quartus 9.1 and try to setup AS you will need that patch. the sof files generated by quartus 9.1 are okay but the stuff that generates epcs related files does not. or if you have access to a quartus version prior 9.1 (for example 9.0) then use a script to generated those files from sof and elf
