16 years agoMy projects don't run.
Hello to everybody. I have DE1 (with EP2C20F484C7 FPGA device and EPCS4 serial configuration device). I run Quartus II v.9.1 web in a Vista computer. I have set up USB Blaster driver software in m...
16 years agoHi,
this sounds perhaps to be related to the problem with compressed programming files generated with v9.1. You should check for the "Generate compressed bitstreams" option in Settings -> Device -> Device and Pin Options -> Configuration to be deselected. Hope that helps Carlhermann
