chalieRobert
1 year agomouse error in using signalTap
there is a block shadow following my mouse while I'm viewing data, how to fix it ?Thanks. See attached for more. I don't konw which board is convient.
FvM
1 year agoI can confirm, that I see the same corrupted cursor bitmap in quartus_stpw 24.1std.0 Build 1077 when moving ther cursor over waveform zone, where a magnifier glass with crosshair should be displayed. I see the bug on different computers, OS is Windows 10 Pro respectively Enterprise, most recent Build 19045.
I see the same problem with 24.2 Pro, 24.3 Pro and 25.1 Pro Signaltap but not with pre 24 versions, e.g. 23.1std. Display resolution is 1920x1080. The problem doesn't occur when forcing VGA resolution by connecting a different Monitor.
