DNguy4
7 years agoMemory IP for PAC card
When I use the Intel Arria10 development board, I can generate the memory example design and select the Arria10 development board, then copy the memory IP to my design and use it. However, I don’t se...
Deshi_Intel
7 years agoHI,
Ok, I get what you are doing now.
PAC card design flow is different from traditional Quartus design flow. You can't use Quartus flow to migrate your existing A10 evaluation board design to PAC card.
PAC card design flow is developed based on the acceleration stack software where it will instantiate all the periphery IP (like PCIe, Ethernet and DDR4) nicely for user.
User is expected to develop FPGA core logic AFU design only to interact with the FPGA periphery IP. You can check out AFU design development guideline in below link.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-afu-dev.pdf
You can also find more doc guideline for A10 PAC card in below link
https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/acceleration-card-arria-10-gx/documentation.html
dlim
