15 years agoMemory DE-70
I have a question about the memory of the FPGA. I use the kit DE2-70 and some IP from Altera (FIFO, RS coding and FFT). By adding a new block, the compilation fail because apparently there is not enough memory (M4K). However I use that 85% of the internal memory of FPGA. Only the ip uses memory. Is this normal? Is there any way to configure the ips it uses for other types of memories? A build option? Thank you for the help. PS: sorry for my english!No RepliesBe the first to reply
