15 years agoMegaFunction Wizard Import LIbrary - Callback
When I try to import a component into System Contents Library (In SOPC Builder), I got Loading Component with TCL callbacks popup error window: This Component defines TCL callback functions. Component Editor does not save TCL callbacks. IF you eidt this component, the callback functions will be removed. How do I import component into library (SOPC Builder) correctly? Also how to install a component that can be preloaded into SOPC builder's System Contents LIbrary? Thank you, DavidNo RepliesBe the first to reply
