MCIO to PCIe Host Adapter for Agilex 7 M-series Dev Kit
I need help to choose the right MCIO cables and MCIO-PCIe Gen5 adapter to connect an Agilex 7 M-series dev kit to a host over CXL (Compute Express Link). The host is a Lenovo workstation featuring 2x Intel Xeon Gold 6416H (2x18-core, 45MB Cache, up to 4.20GHz) and 4 PCIe 5.0 slots.
Is there a recommended set of MCIO cables and MCIO-PCIe adapters that have been tested and with Agilex 7 M-series dev kit?
In theory, I should be able to use this MCIO-PCIe adapter together with two MCIO SFF-TA-1016 8i cables, but could find no cross reference to supported hosts and FPGA devices.
Thank you for your help,
Denisa Constantinescu
- RongY_altera
Contributor
Hi Denisa,
The Agilex 7 I-series Dev Kit (2xR-Tile+1xF-Tile) MCIO connector can work with Amphenol cable P/N: HMC74-1492 in a PCIe Gen5 test. This is the only info I have so far. Hope this helps.
Rong
- Denisa
Thank you for the information.
Regards,Denisa
- RongY_altera
Contributor
Thanks for the feedback. I'll close this case.
Rong
- Jzone315
Hi Denisa:
Have you tried this adaptor and cable you mentioned above,we looking for this adaptor too.
Regards and thanaks.
- Denisa
Hi Jzone315,
We tried the mcio-PCIe adapter but could not make the FPGA PCIe device visible from the host side. Unfortunately, Intel/Altera does not provide a PCIe design example for the Agile 7-M series, so we adapted the one available for the I series. Said this, I am not sure if the problem is the cables, the adaptor or the PCIe IP design.
Dear Altera/Intel Support,
According to the documentation ( https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/agilex/agm039.html), a PCIe 4.0 Design example is provided, but I could not possibly locate it. Is there any chance there will be a reference design for using the PCIe on the Agile 7-M series dev kit? If not, is this still the official channel to get post-purchase support to help Altera FPGA users get the basics working?Thanks,
Denisa
- Jzone315
Hi Denisa:
Yes,we tried this mcio-pcie adapter too, also failed to work, we are pretty sure that it is the problem of this adapter, but intel does not provide this adapter, nor does it provide a link to buy
- ihsan28
Hi All,
Have you got any updates or progress regarding the PCIe access for Agilex 7 M-series? I am starting work with that. Thank you.
