Armando1989
1 year agoMAXII CPLD ADDRESS GENERATION GLITCHES
Hi There Im working on VGA module with EPM240T100C4, all seems fine except adress bus outputs. Im facing glitches, which not present on questaSim gate analisys but are present on logic analy...
- 1 year ago
I overlooked clk definition in .sdc file which is basically o.k. and should be sufficient to report timing violations in internal logic. Reported Fmax is about 140 MHz, suggesting much of timing margin. I don't see how the glitches can be brought up in address counter and mux logic. I rather guess it's an logic analyzer artifact due to insufficient ground connection or unsuitable level threshold setting. I presume that address lines are not externally driven during glitch period.
FvM
1 year agoHi,
I'm not so familiar with Verilog but this should work
?{ADDRESS_BUS_WIDE{1'bz}}:
or simply
?{1'bz}:
- Armando19891 year ago
?{ADDRESS_BUS_WIDE{1'bz}}: that one did the work, ?{1'bz}: this would just float first bit but not the whole.
Thanks FvM!
BR
