MAX10 FPGA Develop kit replacement (repair) request
Hi Sir
Thanks for your patience. Done checking with customer service team, your device is still in warranty. We will proceed with RMA proses. Before proceeding with dev kit RMA, Intel requires details information for RMA (Failure Analysis) request. The failure description you provided is too general to understand the actual failure behavior at your site. Intel requires details information. Please help to answer questions below in order for us to better understand your position.
1. What is the failure symptom? Please elaborate the failure symptom in detail.
2. When did the failure happen? How you discover the failure?
3. How did you determine the failure? Please elaborate the procedures.
4. Does the failure unit ever working before failure?
5. Did you swap the failure board with a known good board?
- wuhannus6 years ago
Thanks for the help.
The following is detail answer.
The failure symptom is when the FPGA board is turned-on, there is light short-current sound.
The failure FPGA board is still able to upload the SOF files.
During the measurement, we use micro probes contact with the HSMC pins directly to read data from the pins. At intial measurement, it works well. After several times measurement, it doesn't give any data signal out. The measurement pin will stay high or low for all the time. Then, after turn-on and off again, we hear the short-current sound.
The failure is determined by the successul measurement of previous several times. And compared with our third FPGA which is still working good with no short-current sound.
Yes, the failure units ever working before failure.
Yes, we repeat the same measurements between failure boards with the known good board.
Please feel free to let us know if you have any more questions.
