MAX10 10M50 Development kit
Thank you very much for your response. I had two versions of ubuntu and i set default 18.04 which as i saw is the one i need and also changed the version to 1 from 2. I also changed the nios2-download file just in case based on the instructions that you send me. Now,
1) Okay BTS cannot work with compatibility options. I do not mind that. But..
2) I want to find the reason why at nios2-shell i cannot run the command nios2-terminal in order to see the IP of my FPGA kit as the user instructions say. My question is the follow: Does a file nios2-terminal has to be exist inside nios2eds folds? cause i cannot find any file in my computer with such a name. Also i have the switches on my FPGA to load default options. Do we need any specific .soc file to be implemented? cause the only one i have based on the terasic site and the basic files is the dual_boot_image.sof.
Thank you again for your time you take to help!!
