MAX10 10M50 Development kit
Thank you for the information provided. It seems the path already set up. I would like to ask you to try on these.
1. Give administrator privileges to Quartus
- Make Quartus run with Administrator privileges, or else you will get issues like Design Templates failing to install or being unable to save Platform Designer (i.e. Qsys) projects.
- From the Windows Start Menu, right-click on "Quartus (Quartus Prime 22.1)" and select More > Open file location.
- Right-click on the "Quartus (Quartus Prime 22.1" shortcut and select Properties.
- Click on the "Advanced..." button and check the "Run as administrator" checkbox. Click all of the OK buttons to save everything.
2. Setting up Windows Subsystem Linux (WSL)
https://www.terasic.com.tw/wiki/Getting_Start_Install_WSL
For board test system, I downloaded it and from my findings:
- It seems from the readme.txt file included in the folder showed that the requirement for the demo are supported on Quartus II version and the operating systems are either Windows 7 and XP.
-This is most of time might be the important factor in running the board test system.
