MAX V CPLD Development Kit - Will not work for a simple logic circuit
Assuming I have the right board, J6.9 and J6.10 are incorrect for N1 and N2. N1 and N2 are on J6.6 and J6.5 respectively. See page 2-8 here:
Hell sstrell,
You have the right board.
Pins J6.9 and J6.10 are the two AND gate outputs. Also, I accepted the 3.3 LV default. When I test with external switches to the board and outputs to a O-scope, nothing. See attached pictures.
Am I to have additional pins connected. If I am using 3.3 LV, what must be done with the other power level pins?
Thank you.
- sstrell5 years ago
As I stated, N1 and N2 are the MAX V device pin names, but they are actually connected to J6.6 and J6.5, not J6.9 and J6.10. Attach your scope to the correct pins to see the outpu.
- Moe15 years ago
Hello Sstrell,
Will check.
Thank you.
- AminT_Intel5 years ago
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
- Moe15 years ago
Hello sstrell,
I been away on work travel. Still on this project, no success.
I am still having problems. A PDF file is provided. The logic circuit is simple. Board not working the way expected.
Thank you.
