18 years agoMAX II Dev. kit programming
Hi, I enconter a strage phenomena: when I try to program the EPM1270F256CS5 I imediatly get an error: "Error: Operation failed" (the progarming is not started at all). This accures with every f...
18 years agoHello Ran,
I compiled your minimal design and also was able to download it to an EPM1270. I wonder, however why your device shows ALTERA04-0 Silicon ID while I have ALTERA04-1. I read about an issue with engineering samples that couldn't be programmed from retail version programming files. Does your device have an ES extension stamp? If this is the case, a special project setting could be necessary, but I don't know where. Regards, Frank
