RobertoP
5 years agoMax 10 instability issues, what to check
Hi.
I have migrated an existing project from a cyclone 1 FPGA to a MAX10 FPGA.
I had no constraints, I have added just master clock that is a 32MHz clock. External signal can be asynchronous (fro...
RobertoP
5 years agoMissing any other answer, I’ll try to define some points to check, in the hope that could helps any other user with similar issues.
Object: Migrating from old design (Cyclone 1) to new one (MAX10)
Problem: strange behaviours, unstability, FPGA do the same thing but whit random errors and blocking issues.
Solution:
- Migrate library components, as FIFO
- Check any new or modified pins and set for most conservative approach (High Z input explicitly set)
- Check Intel Design Guidelines (Eg: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-design-recommendations.pdf ) and apply what is missing:
- Clock schemes
- Latching of external asynch signals
- Reset management
- Optimize for safe state machine, grey coding of states, optimize for stability
Migrating this way, my old design finally passed a quite severe testing procedure, involving also thermal testing at -30 and +64°C
Thank you,
Roberto
