RobertoP
5 years agoMax 10 instability issues, what to check
Hi.
I have migrated an existing project from a cyclone 1 FPGA to a MAX10 FPGA.
I had no constraints, I have added just master clock that is a 32MHz clock. External signal can be asynchronous (fro...
SyafieqS
5 years agoRoberto,
Have you look at the Quartus Design optimization? This could help you to meets the design goals while reducing area, critical path delay, power consumption, and runtime.
RobertoP
5 years agoThank you Syafieq
Already seen.
- Is the reported behaviour a common issue in analogous situation? Never heard before?
- could gray code for machines state improove stability? Or it is just a lucky happening that this work?
- any other Quartus suggested optimization setting to mitigate described behaviour?
- any other VHDL code design aspect to pay attention for?
Thank you a lot,
Roberto
