Gouri
2 years agoMax 10 FPGA Temperature issue
Hello We are using max 10 FPGA (10M16SCU169I7G) industrial grade- working temperature ranges from -40°C to 100°C When the board is powered UP, FPGA temperature reaches to 40 °C without programming....
Ash_R_Altera
2 years agoHi,
Along with recommendations from community member FvM, I would encourage you to go through following links:
https://www.intel.com/content/www/us/en/docs/programmable/683400/18-0/power-management-overview.html, especially section 2.3.
Intel® MAX® 10 FPGA Early Power Estimator (EPE) Design Tool
You should also think of have a proper cooling solution for the device. The EPE can help you with some recommendations for that.
Hope this helps.
