Amir3
3 years agoMAX 10 - Internal ADCs - analog inputs configuration
Hi, We want to run the internal ADCs on the 10M25DAF256I7G FPGA. In this device, there are 2 dedicate analog inputs called "ANAIN1" and "ANAIN2", and 16 pins for analog input or I/O (under bank 1A)...
Mengzhe
3 years agoHi,
- For 'The plan is to use part of the 16 pins as analog input and the other as I/O'
As mentioned in Intel® MAX® 10 Analog to Digital Converter User Guide:
'If you use bank 1A for ADC, you cannot use the bank for GPIO.'
so other pins cannot be used as I/O.
- ADC_VREF = 2.5[v]
That's right.
- VCCIO1A = 3.3[v]
Refer to Intel® MAX® 10 FPGA Device Family Pin Connection Guidelines:
'If you enable the ADC feature, connect VCCIO1A and VCCIO1B to 2.5 V.'
Besides, for ADC, power supply VCCA_ADC and VCCINT are needed.
BR,
Mengzhe
