RVanD5
1 year agoLVDS_TX error on too many fanout, but connected to single pin - C10LP
I have a very simple project where we migrate a Arria 10 NCO design to a Cyclone 10 LP. We regenerated the LVDS IP as this is different on the C10LP. But we get this error: Error (15885): Output ...
- 1 year ago
the error is caused by ALTLVDS_TX tx_outclock connection. You are using it to drive NCO IP in your design. Honestly I don't understand why, that doesn't seem to make sense because tx_outclock is intended only as a reference for LVDS output signals. Fortunately we don't need to understand the design objective to fix the error.
Problem is that tx_outclock is the output of a DDIO_OUT block rather than a direct PLL clock that can be used internally. If you want access to LVDS_TX fast_clock PLL signal, you need to switch to ALTLVDS_TX external PLL option. Or generate 300 MHz clock with other PLL.
Frank
FvM
1 year agoHi Rob,
you are right, no Cyclone 10 LP I6 speed grade available, unfortunately. Go for Agilex 3?
Best regards
Frank
