ymiler
Contributor
2 years agoLocate all FF in the OBUF
Hi What is the constraint to locate all the FF in the OBUF ? I need a minimum and constant routing latency for each synthesis
- 2 years ago
Seems like you're using Pro version. Then probably can use GPIO IP under section I/O in IP Catalog. The register mode choose DDIO.
ShengN_altera
2 years agoHi,
Probably can use DDIO IP for ODDR.
Sheng
- ymiler2 years ago
Contributor
DDIO ?
There is no IP name like it in the IP catalog
