ymiler's avatar
ymiler
2 years ago
Locate all FF in the OBUF
Hi What is the constraint to locate all the FF in the OBUF ? I need a minimum and constant routing latency for each synthesis
  • ShengN_altera's avatar
    2 years ago
    Seems like you're using Pro version. Then probably can use GPIO IP under section I/O in IP Catalog. The register mode choose DDIO.
