LoanIO. How to connect exported LoanIO signals to top level ports.
Hi, thanks for the reply.
Yes, in the rush of solving issue I re-asked about the topic.
Key was to use loanio pins 49 and 50, and not 60 and 61 as one may infer fro Platform Designer at first sight (Likely the extreme reduced size of the GUI in 4k screen added more difficulties to the proper setup). This can be confirmed in DS1 board schematic or the pin planner (pins B25 and C25 are mapped to io 49 and 50)
As for the connection here the information which brought clarity for me:
https://forums.intel.com/s/question/0D50P00003yyQXbSAM/how-to-let-fpga-get-access-to-hps-pins?t=1557442829227&searchQuery=
It was also mandatory to:
- define the HPS_UART_RX and TX ports as inout in the top level, otherwise synthesis will fail
- to program preloader with the hps configuration. (I need to confirm whether u-boot was also a requirement in the SD card as well). Its worth mentioning that rev G of the board has removed the programming select switch, so no QSPI interface available, SD card is simplest approach.
Finally I'm getting the UART properly interfacing HOST<->FPGA in CycloneV
From brand new board box to working system it took likely 40 man hours for experienced FPGA engineer.
